![]() | Home > Technical (L322) > Strange clicking noise from passenger seat |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Is it a consistent ticking noise or a random clicking? |
There is the body control unit under the passenger seat BCU, but I have never heard any clicking sounds from mine. Had a TD6 for 6 years and the only clicking or ticking sound I ever heard would be the fuel pump located under the car by the passenger side rear wheel. This I suppose could appear to sound like its coming from under the passenger seat. Maybe the fuel pump is more noticeable/noisy when the car is 1st started. |
Taximan2011 Member Since: 15 Jul 2013 Location: Somerset Posts: 15 ![]() ![]() ![]() |
Random clicking. Noticed it when I was sat in traffic about ten minutes after starting car. It sounded like it was under passenger seat but could have been misheard New L322 Owner - |
Well I can only think its the BCU as that's the only electronics under the passenger seat. Unless its something mechanical that's not inside the car. |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201 ![]() ![]() |
. . . Funny that. I was about to ask the same as mine does it, too - '06MY AJV8.
jimwise68 Member Since: 29 Feb 2012 Location: Chelmsford Posts: 12 ![]() ![]() ![]() |
bit of a thread resurrection. But my 2002MY Vogue has just started doing this. Did you find out what it was? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 957 ![]() ![]() |
Mine does this too, regular ticking sound, not too loud, from cold startup but seems to disappear after 15-20 minutes.
sounds like a relay or rocker switch turning off and on and its definitely coming from under passenger seat.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Just a thought - is it anything to do with the FBH located under front wing outside passenger footwell.?
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Madagascan cockroach ? .
"Madagascan cockroach"
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Taximan, could it be the meter......
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Fbh fuel pump👍 There is nothing that can't be fixed with a hammer😜😜
