![]() | Home > Technical (L322) > TDV8 3.6 early cut-off problem during fuel fill-up |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 222 ![]() ![]() ![]() |
Hi,
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Happens to me all the time. The fuel back pressure caused by the fuel filler pipe in the car is always causing fuel nozzles to cut out on me. I find I have to carefully regulate the fuel flow to get the tank full. A real pain but there doesn't seem to be a solution. 4.4 TDV8 Vogue Baltic Blue MY11 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
wasnt there a thread about turning the nozzle upside down to solve this.. ... - .- -.
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 205 ![]() ![]() ![]() |
Yep bugs me every time I fill up too but after Stan's suggestion about other threads I did a quick search and found these:
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 745 ![]() ![]() ![]() |
Turning the nozzle up side down does work but I think there is also a TSB to fix this issue, it has been mentioned in a previous thread but I think it was a complex fix involving removal of the tank. 2021 P400 Silicon Silver AB
My latest TDV8 does NOT do it |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Jez000, any other details on the TSB?
Jez000, just noticed the links above, so will check out the TSB's in question. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I have the same problem with mine. Turning the nozzle upside down does work. I also bung the filler cap in the handle to keep it on so I can stand around watching instead of holding the nozzle. It still cuts out automatically when full. |
Thanks for all the replies and Ian for the links to the other threads. I have always pumped the fuel at about half speed as it always cuts off after a couple of seconds at full speed. Even so it usually fills the tank up full so I just wondered why it wouldn't fill completely on those two occasions. I'm reluctant to pump any slower in case it doesn't cut off at all and the tank overflows (had that happen once before, suddenly felt I had wet feet... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Pump nozzle at 12 o clock works best for me. Still cuts off when full. |
