![]() | Home > In Car Electronics (L322) > Headlamp |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
probably a glitch...try turning the ignition on/off a few times and/or check the connections on the back of the headlight.. ... - .- -.
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
Sounds like it could be motor failure but you could check fuse no 48 which is for the left hand light behind the glove box the right hand one is fuse 54. Hope this helps. Should add it depends if the fuse box locations are the same in the later TDV8s if not check your handbook Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
Headlamp cured itself range rover gremlins strike again Thanks for the advice |
