Home > Technical (L322) > Solar Battery Charger |
I use mine and connect to outlet in boot as that's always live. left it for 2 weeks when I was on hols came back started no issues. Present :2008 TDV8 HSE
29th Oct 2013 11:23pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Use it in the rear quarter window Nd plug it into the rear fuse box |
30th Oct 2013 12:22am |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
My 2003MY TD6 fag lighter is live all of the time - Very handy!
31st Oct 2013 12:10am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
I struggle to see how the very low current (and voltage) from these solar chargers could damage the ECU - especially as when the charger is being used, the ignition would normally be off (and the SRS ECU should have powered down too - not much need for SRS in a parked car). Sounds like one of these issues where the dealer look for a reason to ensure that they can make the punter feel it's his fault and therefore expensive and not covered by a warranty... |
31st Oct 2013 3:35pm |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 |
I fitted one on my dash and connected to the fag lighter socket in front of clock.
31st Oct 2013 4:08pm |
I think the power spikes/fluctuations during starting could potentially damage the solar panel.
31st Oct 2013 4:19pm |
g1968g Member Since: 24 Aug 2013 Location: Fife Posts: 89 |
Hi,
1st Nov 2013 12:38am |
