Home > Maintenance & Mods (L322) > brake 'grind'
brake 'grind'
i have an annoying brake grind noise when i come to the final seconds of a slow stop..its very not loud but because i know its there ,its bugging me..
googling suggests that its damp/rust on the discs and when braking the pads slip a little and cause the 'grind' ..i suspect that this is the cause as this noise disappears when the discs are hot ..the pads are about half worn btw,,
i have seen these 'green stuff' pads that claim to eliminate any kind of vibration and brake grind noise so has any one tried these and are they recommended.. ... - .- -.
Post #218202 23rd Oct 2013 9:02am
Stan, check ya don't have non OE pads fitted pal... OE all the way with your Brembo's IMHO...
Post #218203 23rd Oct 2013 9:05am
Sounds like your wallet need some lubrication Laughing Laughing
Post #218204 23rd Oct 2013 9:06am
i'm pretty sure they should be OE pads as the range has always been serviced by a main dealer but unless i have a physical look i cant confirm that.. ... - .- -.
Post #218205 23rd Oct 2013 9:07am
me spend money John? Laughing ... - .- -.
Post #218206 23rd Oct 2013 9:08am
Have come across plenty of non gen pads doing this... Many with FMDSH Shocked
Post #218209 23rd Oct 2013 9:11am
interesting that Craig Neutral
any opinions on the green stuff pads? [or red stuff ?] ... - .- -.
Post #218212 23rd Oct 2013 9:14am
IMHO (I've only seen them used on Disco's) they are rubbish on such heavy cars...
Post #218214 23rd Oct 2013 9:16am
ebajema
Mine has OE pads from the dealer and does it a bit at times as well. Especially when I have been sitting in slow traffic for a bit. It's more like a squeak. MY 2010 5.0 SC Galway green and sand interior!!
Post #218224 23rd Oct 2013 10:00am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
OE for me every time.......... Rolling Eyes
Post #218273 23rd Oct 2013 1:02pm
ebajema
Just came back from lunch and sat in traffic for a while and it started again. Disappears as soon as you start driving "normally" and braking normally. It is only on the very slow braking where it makes the grinding like noise. Again all brake parts (discs, pads, calipers) are OEM. MY 2010 5.0 SC Galway green and sand interior!!
Post #218289 23rd Oct 2013 3:49pm
strangely today whilst taking the wife to hospital and back it didnt seem to make this noise , mind you its been dry and windy so did that dry out the brakes? ... - .- -.
Post #218308 23rd Oct 2013 5:56pm
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
well said .. Thumbs Up i had the yellow ceramic one on my one,took them off after a week,,the squeaking done me head in...apparently these high performance pads are a waste of money on these vehicles,they are alright on your a.m.g merc , mtech bmw or on the porsche carrera's with the 4 pots or 8 pots caliper as they are speed machines, but on the 4x4 they don't have that desired effect.... plain r.r pads for me from now on...
Post #218545 24th Oct 2013 10:07pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I get a bit of squeaking in traffic now and then but I had hat put that down to the back pads and discs needing done as they're on there last legs.
Gonna go for Delphi pads.
Post #218548 24th Oct 2013 10:24pm
@Steve, i've had a google and it seems these yellow,green and red pads are pants on heavy motors like 4x4's so its going to be a well known make i replace mine with but which 'well known' make is better..
as it happens the grind noise is no longer there , well at least on my last couple of journeys Confused .. ... - .- -.
Post #218590 25th Oct 2013 9:03am
