Home > Technical (L322) > Air con Pump
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Air con Pump
Another tech question for those more enlightened than i!
Am i right in thinking i could remove the air con pump from my TD6 and run the car without it on for a while? Obviously i'd have to isolate the electrical feed but is it ok to do? Also is it just a case of removing the 2 10mm bolts, the air con pipe from the top and the 10mm on the electrical feed?
The reason i ask is two fold, firstly as you might have seen in another post i have a coolant leak that i can't trace and its dripping from the air con pump/compressor. Hopefully removing it will lead me to the promised land!
Secondly, the bearings in my pump are knackered and i'd like to see if i can get in to the innards and replace these bearings and give it a refurb.
Any advice gratefully received.
Post #217990 22nd Oct 2013 12:49am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Two things to be aware of, first you would need to properly purge the AC circuit of refrigerant before disconnecting any pipe work and the second is ensuring the AC pump drive belt does not also drive any other ancillary device e.g. Water pump, Power steering pump and or alternator. If it does the belt will be too long when your AC pump is off the car. Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #217991 22nd Oct 2013 3:18am
paul271
It's a separate belt mate as there isn't one on there at the moment.
Post #217992 22nd Oct 2013 3:23am
B9er
Then, once the system is purged of refrigerant, you should be good to go Very Happy Should've been old enough to know better...doh!
Post #217993 22nd Oct 2013 3:25am
paul271
Thank you for your advice squire. Much appreciated!!
I take it I'll have to get engineer to purge the system?
Post #217994 22nd Oct 2013 3:34am
B9er
Quick Fit or some Halfords can do it & if you sweet talk them by promising them you'll get them to recharge your system, they may wave a charge. If neither of those options are nearby, then a mobile AC service is likely your best bet. Should've been old enough to know better...doh!
Post #217995 22nd Oct 2013 3:38am
paul271
Cheers for the advice B9er.
Post #217996 22nd Oct 2013 3:41am
B9er
Your welcome Paul271, good luck in solving you leak conundrum Very Happy Should've been old enough to know better...doh!
Post #217997 22nd Oct 2013 3:43am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Perhaps is this one correct: ??? http://www.ebay.de/itm/Klimakompressor-BMW...3367b4e332 L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #218000 22nd Oct 2013 6:08am
SteveMFr
Site Sponsor
If you drive with the AC lines open, be sure to seal them properly (lots of duct tape, for instance). You do not want any additional moisture in your AC...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
(wife thinks I'm nuts - prob right, too)
Post #218003 22nd Oct 2013 6:25am
paul271
I'll double check meerbusch thank you.
Steve thanks for the heads up.
Post #218047 22nd Oct 2013 10:05am
paul271
Nipped in to Halfords today and they de-gassed my Air con so i'll tackle removing it tomorrow! Should be fun!! Confused
Post #218376 23rd Oct 2013 8:09pm
B9er
So far, so good Very Happy hope it all continues in the same vein Thumbs Up Should've been old enough to know better...doh!
Post #218398 23rd Oct 2013 9:10pm
paul271
Me too mate!! Took in to my Indy today and they agreed the pump needs to come out to find the leak.
Post #218402 23rd Oct 2013 9:19pm
paul271
Well it was a pretty straight forward process! Although there was one sphincter twitching moment when I went to start the Rangie after I'd finished and it wouldn't even turn over!!!
That's what happens when you remove the earth strap thats mounted on the air con pump and forget to bolt it up somewhere else!!!
One problem though is that I now have no climate controls what so ever.
Post #218524 24th Oct 2013 6:29pm
