![]() | Home > Technical (L322) > Is cruise control 'economical'? |
Without doubt its more economical to use your right foot... The CC is control'd by an ECU that has one sole purpose in life and doesn't care how open the throttle is to achieve that goal... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35876
only use mine in long motorway contra flows to keep my speed steady.. ... - .- -.
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Use mine quite a lot on long Mway trips (i.e. Europe) but switch to manual if it is a long steep uphill and then re-engage at the top. Still get an avge 20 mPG (v8 Petrol) |
Use mine whenever I can, as long as the road is clear, especially speed restricted areas (OK, which is everywhere) but find it useful at 30 as well as at 69mph.
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
The difference would not be enough to warrant worrying about using it. You buy a Range Rover and then worry about using cruise.... |
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
I'd even use it down my 20 metre drive, if I had the time! Previous cars:
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Wish my VX had it. |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
I've found it better. When I'm doing say, 60 and I switch on cruise, the revs drop off but I'm still doing 60. I can't manage that manually - must be my feet! The range figure increases in cruise for me.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
The best "cruise control" was the one Alfa Romeo used to have. It just held the accelerator mechanically using a cable with friction "lock". Didn't come off when you pressed the brake or clutch so you would have to do that yourself.
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
^^ Agreed there, Noddy, to manual mode.
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
I heard that it is not safe to use cruise control in wet or heavy rain conditions. I thought it was one of those internet myths, but apparently not. Heres the reason.
| Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112
We had a safety alert at work about not using cruise control in the rain.
I don't think I'd ever use cruise in the rain |
