Home > Technical (L322) > 4.4 TDV8 intermittent momentary power loss - what th...?
GregMilner
Australia 2012 Range Rover Westminster TDV8 Fuji White
Can anybody point me in the direction of threads which discuss this?
I've noticed on several occasions my 2012 TDV8 suddenly loses power for a couple of seconds, eg when exiting a corner or taking off from the lights.
It's as though the gearbox suddenly gets all confused, the revs drop below 1,000 and then it picks up again all by itself.
When it happened the first time (I've only had the car a couple of months) I thought I must have been imagining it, or I'd backed off the throttle without realising it, but it's happened several times since.
It's been suggested to me that it might have something to do with a sticking exhaust gas recirculation valve.
Any clues would be greatly appreciated:-) 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Gone: 2010 RRS 3.0 TDV6, 2007 Audi TT 3.2V6 Roadster
Post #218789 26th Oct 2013 4:56am
Philip
Experienced the same a couple of times - felt almost like the gearbox couldn't find the right gear for a split second when accelerating from low speed. Dealer reflashed software (to cure the ~70mph hesitancy), can't remember noticing it since.
Post #218845 26th Oct 2013 11:57am
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Mine used to do the same,never did anything about it tbh. If you have nothing nice to say,say nothing at all.
Post #218846 26th Oct 2013 12:21pm
d3rm0
Greg my 12MY does it aswell. I thought it was the legendary LR build quality and as it doesn't happen all the time I hadn't bother taking it back to the stealer. Let us know if you get it fixed.
Post #218934 26th Oct 2013 8:17pm
GregMilner
Okay, I'll take mine to the dealer, they're only a mile away, I'll get them to run some error code checks and let you know how it goes. 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Post #218962 26th Oct 2013 11:57pm
http://www.fullfatrr.com/forum/topic10797....p;start=15
Try that one Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #218992 27th Oct 2013 8:52am
GregMilner
Thanks Martin. I've had a read through that thread, seems most of the guys talking about it in that thread have had issues with regards to decelerating from high-ish freeway speeds whereas I've only noticed the issue while accelerating from fairly low speeds. But it does seem to be a similiar problem to do with the gearbox mapping, so will get it checked at the dealer this week. Will report back when they've run a laptop over it.
Thanks for the heads up. Smile 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Post #219009 27th Oct 2013 9:58am
GregMilner
Well, had the service dept run some checks today. They say they ran all the diagnostic checks and foun no error codes anywhere. A good thing, I suppose, but doesn't answer the question as to the intermittent power loss. Still, they reinstalled the relevant software, so I guess it's a case of watch and wait.
Interestingl, it was due for its first service, for which I was quoted about $1,000. My regular idependent guy quoted 'about $300' for the same service. With the top quality synthetic oils. Mmmm, it's a toss-up. 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Post #219713 30th Oct 2013 1:04pm
Thats a difference!
Try a bit of haggling, cant hurt, the list of stuff they should do on a service is quite long and it maybe that the indy will just do the oil and filters. There is nothing that can't be fixed with a hammer😜😜
Post #219736 30th Oct 2013 3:43pm
GregMilner
He's a Rangie specialist, used to service my previous one, he knows exactly what's specified for a first service and does the lot. Plus, he picks up my car from my office and delivers it back at the end of the day:) 2012 L322 TDV8 Luxury
2013 VW Polo GTI
Post #219872 30th Oct 2013 11:31pm
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Intermittent power loss
Greg, I now have same thing - for no more than 1 to 1.5 seconds, low revs, 'pauses' then takes off again; odd sound -whirring' accompanies it; wondering if it's turbo related. Will get Stealer to take a look.
EDIT - Found the answer in Search Embarassed
http://www.fullfatrr.com/forum/topic10797.html
ECU and gearbox reflash here we come
Post #257603 4th May 2014 2:45pm
BlackPerth
all fixed and running perfectly: Thanks to Australs Land Rover Brisbane, 2 x Technical Bulletins - reconfigured power train control module with latest level of software; and carried out modified turbo drain pipe
cheers and thanks to all for helping me help the dealer resolve this.
Post #262022 29th May 2014 7:03am
