![]() | Home > Technical (L322) > Can you stop the steering wheel from retracting? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Mine's started working again and every time I turn the car off it retracts. This is: -
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
I turned my "easy entry/exit" feature off with the IDTool. The adjuster stalk still works so the wheel can be fine tuned after placing ones behind in the drivers seat and the memory positions still work. Geoff |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
David, if it has not worked until now, first try a battery reset... If that does not work just unplug the motor |
I have no ID tool. |
Hi Craig - it started working again when I had the tyres changed and the tracking done. Bizzare that it just decided to start again. |
No IIDTool then do what Craig says.
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
Have you tried turning the steering column adjuster? Push, pull ,up and down moves the column and a twist should switch the automatic retract on and off.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
What about puting it all the way in then saving to memory that position? Or would that be too far away for you to drive? Previously..
I want it all the way out! |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
On the 2010 My you can switch it on of off on the dash |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Just seen this post never though about it but mine done work now but I have had the auto door locking turned off on moving has this any link to it or anything else I have turned off it still works on the stalk |
roger 47 Member Since: 24 Aug 2012 Location: Exmoor Somerset Posts: 80 ![]() ![]() ![]() |
Fuse 20 and 23 in the passenger compartment fuse box. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
looked at them today both look ok
What I should have said is to set the steering wheel where you want it and then take out the fuses, it would stay in that position.
