Home > General > Info or help....
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Info or help....
Ok, does anyone know how much the garage charge or is there anyone around the Bath, Bristol area that could activate my park heat.
as SteveMFr says:
If you only have timed ventilation in the menu, you will need park heat activated and then the telestart bits. If you have park heat in the menu all you need are the telestart bits or just use the timer. The tlestart bits will not work w/o park heat activated. As I've posted before, the only units that I am aware of that will allow park heat activation are the OEM T4/IDS/SDD, Autologic, BBS MSV, or IIDTool.
I would be very great full Thumbs Up
Steve
Post #220258 1st Nov 2013 11:01pm
Cam-Tech-Craig is near. Comes well recommended.
Post #220259 1st Nov 2013 11:04pm
^ +1 ...dont go anywhere else Steve. ... - .- -.
Post #220296 2nd Nov 2013 11:10am
