Home > Maintenance & Mods (L322) > sunroof won't slide
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
sunroof won't slide
Hi there, my sunroof doesn't slide back on my L322 Vogue. It goes up and down alright but no slide. Any quick tips to try ?? Razz
Post #220513 3rd Nov 2013 6:50pm
comports
Do you hear any noises when trying to open it?
Its probably either jammed (if you don't hear the motor turning) or come off the track (if you do hear it)
I think its a pain in the butt to fix though and may even be roof lining down! Ash
2016 SDV8 AB
Post #220515 3rd Nov 2013 6:53pm
mjdronfield
You can press the button for about 20 seconds or so and the motor will recalibrate itself
Can't remember if you hold it in the close position or keep it pushed up after you have tilted it.
I am sure there is something on here about it if you have a quick search.
That will work, providing you don't have something broken etc..........
Hope it helps 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #220516 3rd Nov 2013 6:57pm
Its in the handbook.
But mine is at home Rolling Eyes
I think you hold the swich in the closed forward position until you hear a click, then it should work fine....
If it doesnt more investigation will be required. There is nothing that can't be fixed with a hammer😜😜
Post #220518 3rd Nov 2013 6:59pm
Steverr
Thumbs Up Thank guys, i will give it a go when it stops raining !!!!
Post #220520 3rd Nov 2013 7:03pm
