Home > Maintenance & Mods (L322) > leaky sunroof |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Is it the furry seal? If it is then why not glue it back? If memory surves me right that fury seal doesn't stop all water, more of a dirt protector. The sunroof drains should deal with any water getting past unless you have a blocked drain? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
4th Nov 2013 9:22pm |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 |
I had water from the roof, last monts.
6th Nov 2013 12:51am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Fuzzy seal there just to keep dirt/leaves/pine needles/etc out. It is NOT supposed to be waterproof. Whenever it rains, water will get in, then it SHOULD be channelled through the drain tubes. If drain tubes are working - no problems. Clean them out using a piece of plastic cord (as used in a weed wackier). Do NOT try to blow them clean using compressed air! Don't ask how I know this! |
6th Nov 2013 7:52am |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 893 |
cheers everyone, the sun roof was actually jammed open (only a little bit)
7th Nov 2013 1:31pm |
