Home > Technical (L322) > CAN Bus reader
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
CAN Bus reader
One for those who delve deep into the car network.
I have navcoder and the ibus interface but wondered if there was a better bus reader? I am trying to diagnose a repeating problem on my 2004 v8 petrol and navcoder is telling me all is ok as is RSW Allcomms.
Suggestions would be most welcome Smile "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #221883 9th Nov 2013 6:49pm
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Might help if you explain what the repeat problem is.....
many knowledgeable people on here, all are very helpful... Thumbs Up
not to sure any of them are psychic tho.... Shocked free use of "RSW" all comms to anyone nearby
Post #221972 10th Nov 2013 12:06pm
MrP
Fair point Thumbs Up
Its the regular reboot of the nav / head unit. Its as if the system is rebooting it about every 3 minutes. Its a problem others have had and no solution so far found.
So far I can't see any errors on the ibis to indicate what is going wrong so I wondered if anyone uses a better bus analyser "On first name terms with my local Dealer......now."
Post #221979 10th Nov 2013 12:49pm
hoppy
have you tried the old faithful....
battery disconnect, usually fixes many issues.. free use of "RSW" all comms to anyone nearby
Post #221981 10th Nov 2013 1:37pm
My old one did that once - I just checked all the connections in the compartment in passenger side of the boot and that seemed to fix it.
Post #221986 10th Nov 2013 2:12pm
MrP
Yes battery and fuse 49 tricks already done.
I'm sure it is a bad connection and was hoping to see an error on the bus that would narrow down where it might be.
Next approach is to systematically remove each item until it stops........just need to find the time.
-Si "On first name terms with my local Dealer......now."
Post #221992 10th Nov 2013 2:33pm
