Home > Technical (L322) > Difference 26/28hp
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Difference 26/28hp
Anyone know what the difference between the ZF 6HP26 AND THE LATER 6HP28 is ?
Post #222436 12th Nov 2013 8:05pm
i think the '28' will take the extra power the 5.0 produces.. ... - .- -.
Post #222449 12th Nov 2013 8:25pm
mzplcg
Mostly Jag biased as that's where I got it from but it's the same box just without the transfer case.
The -28 has a much improved torque converter lock up, can handle more torque, and shift as much as four times faster than the original -26.
Model Date_Of_Manufacture Engine Power Transmission
XF (X250) 2006/10 - 2008/04 4,2L V8 - 219 kW / 298 PS 6HP26
XF (X250) 2006/10 - 2009/01 4,2L V8 - 219 kW / 298 PS 6HP26
XF (X250) 2006/10 - 2009/02 3,0L V6 - 175 kW / 238 PS 6HP26
XF (X250) 2007/06 - 2009/02 2,7L V6 D - 152 kW / 207 PS 6HP26
XF (X250) 2008/02 - 2008/07 3,0L V6 D - 200 kW / 272 PS 6HP28
XF (X250) 2008/04 - 2009/01 4,2L V8 - 288 kW / 392 PS 6HP26
XF (X250) 2008/08 - 2008/09 3,0L V6 D - 200 kW / 272 PS 6HP28
XF (X250) 2008/08 - 2008/09 5,0L V8 - 287 kW / 390 PS 6HP28
XF (X250) 2008/08 - 2009/08 3,0L V6 - 179 kW / 243 PS 6HP26
XF (X250) 2008/10 - 2009/07 3,0L V6 D - 200 kW / 272 PS 6HP28
XF (X250) 2008/10 - 2009/07 5,0L V8 - 287 kW / 390 PS 6HP28
XF (X250) 2008/12 - 2009/08 4,2L V8 - 226 kW / 307 PS 6HP26
XF (X250) 2009/06 - ______3,0L V6 D - 200 kW / 272 PS 6HP28
XF (X250) 2009/06 - ______5,0L V8 - 287 kW / 390 PS 6HP28
XF (X250) 2009/06 - ______5,0L V8 - 373 kW / 507 PS 6HP28
Post #222464 12th Nov 2013 9:17pm
Glynn
Maybe Iv'e got the "28" bit wrong then as the new gearbox is apparently off a 2008 R/rover 4.2 supercharged, so what gearbox would this have ?.
Post #222468 12th Nov 2013 9:22pm
info in our wiki Glynn...
http://www.fullfatrr.com/forum/post105033.html#105033 ... - .- -.
Post #222469 12th Nov 2013 9:24pm
Glynn
Thanks Stan,
It's just that they said the box was from a 2008 SC and that two of the numbers were different and that they would have to check with ZF wether it would fit my car which is a facelift 55 reg 6 speed.
So I assumed it must be the 28 model.
Post #222473 12th Nov 2013 9:35pm
