Home > Technical (L322) > Won't start this morning
supershuttle
Ah well 15 minutes of FBH, battery is new big Bosch and car doesn't start Yawn . Is the general consensus FSR change first as no way to test it then if that fails alternator.
I've read on here about lots of checks to do together with long drawn out sagas, one question I have is what voltage should float across the battery with engine running so alternator spinning Thumbs Up Geoff
Post #222574 13th Nov 2013 9:26am
about 14/14.5 volts Geoff.. ... - .- -.
Post #222577 13th Nov 2013 9:28am
13,6v - 14.2v depending whats switched on electrically Thumbs Up
Post #222579 13th Nov 2013 9:31am
supershuttle
Cheers Stan, at least there's no rush to get to work for us retired types Very Happy Geoff
Post #222580 13th Nov 2013 9:31am
supershuttle
Thanks also Craig. Thumbs Up Geoff
Post #222581 13th Nov 2013 9:32am
Post #222585 13th Nov 2013 9:42am
Geoff,
Run her with every electrical gizmo switched on and see if the Voltage stays around 14ish... If so, i would say you maybe have an iffy battery sir Thumbs Up
Post #222588 13th Nov 2013 9:44am
