![]() | Home > In Car Electronics (L322) > Faulty Denso DVD Player for Sat Nav |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Tried a lens cleaner? |
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 ![]() ![]() ![]() |
Will try that |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Unplug it for half hour |
d3rm0 Member Since: 12 Feb 2012 Location: UK Posts: 442 ![]() |
http://www.denso-am.co.uk/navRepair.asp
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
Might be due to the heavy rain causing condensation in the reader. Mine threw up an error and when I ejected the disk, it was covered in a layer of condensation. gave it a wipe and it was ok, but maybe your DVD drive is a bit worse than mine? Got - 2017 SDV8 Autobiography in Loire Blue
Thank you will try that tomorrow |
That was the first thing I looked at no trace of damp |
Unplugged no change |
Now found that I need an upgrade to vehicle settings to enable new double layer DVD to work |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35774 ![]() ![]() |
all the nav discs in 2006-2009 are dual layer so i dont understand why you have to upgrade the vehicle settings and indeed how this is done.. ... - .- -.
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
A lot of manufacturers update the nav system firmware when you insert an updated DVD.
It would appear I have been told a wee porky by an alleged rr "expert" |
