Home > Technical (L322) > Td6 injector code
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Td6 injector code
Can a kind soul check the injector code number on its plastic housing? My car is stranded 400 miles away and I need this code for the repair company. Thank you!
Post #18551 20th May 2010 2:16pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Just pulled all of mine out getting the Turbo out to send away. I can let you know the number in the morning if you still need it?
Post #18573 20th May 2010 11:47pm
adara
Yes please thank you, it's the one on the plastic housing!
Post #18576 21st May 2010 6:21am
elpeede
ok here are all the numbers.
175589022
2503
939 in a oval/circle
0445110266
7785984
The last number 7785984 is on all the injectors , all the others change from one injector to another so I guess this is the one you need.
Hope this helps.
Post #18579 21st May 2010 7:44am
adara
Thank you very much! The injector specialist says that the code is the one with the 0 in front, so it should be 0445110266, but you say it's not the same on all the injectors?
Post #18593 21st May 2010 8:29am
elpeede
http://shop.ebay.co.uk/?_from=R40&_trk...Categories
That number seems to come up trumps on a search.
Post #18617 21st May 2010 1:00pm
