![]() | Home > Technical (L322) > Yet another battery drain issue!?!? 2007 VSE |
NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92 ![]() ![]() |
Worse than I thought then!! No-one got any ideas!? |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
My 2002 Td6 is doing the same (Just cycled into work as I had a flat battery this morning!! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
I have similar troubles and have replaced battery.
Mine also is inconsistent and now carry a set of jump leads all the time.
Jeeessss you lot need to make an orderly queue at my door... Plugging chargers in constantly, not using FBH etc etc that's not what FF ownership is all about!
g1968g Member Since: 24 Aug 2013 Location: Fife Posts: 89 ![]() |
Hi,
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 ![]() ![]() ![]() |
@Supershuttle I am exactly the same and am fed up.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
not had it particularly bad with mine.
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi Nick and not sure what you mean by 450 vs 300 ma.
