![]() | Home > In Car Electronics (L322) > Aux heat |
Hi Steve,
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
Hi Steve I did email you some pics on Tuesday like you asked. I've just tried to run it but turned off after about a minute. I've only got 40 miles fuel at the moment. What should if sound like ? Mine just sounds like the fan is running. I was imagining something like a mini engine firing up ???
Update. When I manually put the aux heat on it goes off after about a minute. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8767 ![]() ![]() ![]() |
Not right. Should keep running.
When I set the timer it goes straight to off... Defiantly doesn't want to work does it !!!! |
Hi Steve,
Thank for the reply Steve |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
How do you service the fbh? And how often? |
Yep just cold air |
I assume you are not hearing the sound of a burn starting either. All you're hearing is the combustion air blower during a failed start sequence - so it seems you have an FBH prob. You'll need to go back to Craig and have the codes read. |
