Home > Technical (L322) > 2010 rear bleed nipples
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
the blighters dont want to loosen and feel like they will snap!
what's the best way to get them loose - remove caliper and heat?
also, what size are they?
Post #224435 22nd Nov 2013 12:34am
No need to remover the caliper to heat them, just don't get them red hot
Post #224437 22nd Nov 2013 12:44am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Warm them up - apply plus gas and use an 8mm six point socket - gently ! Thumbs Up
Post #224462 22nd Nov 2013 9:17am
As well as heat you can also gently tap the end of each nipple with a small hammer about 50 times. Don't overdo the tapping but it tends to break the rust ring on the thread.
Post #224587 22nd Nov 2013 4:37pm
dexion7
decided to buy some new nipples in advance but the fella at main dealers said they never have any problems, no heat, nothing. didn't stock them and couldn't recall the last time he sold any.
i decided to be brave and got to work. they did come loose but it was nerve racking. even with a little penetrating fluid and rocking them back and forth they weren't really getting much looser as though rocking 1/10 turn back and forth with penetrating fluid would take forever if id wanted them out completely.
usually, once you get a rusty thread cracked and then get some fluid in there the thing comes out easily the rest of the way
even tightening them back up again wasn't straightforward. i used an easy bleed so its possible to determine when the nipple is sealed and it felt like they had to be really tight.
the whole episode|: loosening / tightening just felt like someone had at some point crossed the threads. they shouldn't have been out yet since new.
BTW 11mm socket / ring spanner on 2010 calipers
Post #224633 22nd Nov 2013 7:51pm
dexion7
maybe they put them in with thread locker??
Post #224691 22nd Nov 2013 11:23pm
