Home > Technical (L322) > Reversing camera question
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
I am a novise owner of the FFRR 2010 TdV8 Autobiography.
Q1: Mine has a reverse camera, when I have used it an put the car back in drive its still on until I exceed the speed of 30 km/h. Is this normal?
Q2: When I back with a trailor the rear PDC is still active, on my previous D3 this was automatic disabeled when I hooked on the trailor. Is an active rear PDC when using a trailor normal?
Thanks Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #224647 22nd Nov 2013 8:56pm
normal for the first question..
not normal for the second question..when towing your pdc should be disabled so i think that wiring is incorrect.. ... - .- -.
Post #224651 22nd Nov 2013 9:05pm
ksskaret
Thank you Stan Smile
Simon Range Rover TdV8 Autobiography MY2010
Post #224653 22nd Nov 2013 9:07pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
It won't be the wiring, you need the car coded for a tow bar so the PDC is disabled when it recognises that the trailer wiring is connected Wink
It's one of the few things a dealer can do for you although they will probably charge unless you ask nicely when it's in for something else Whistle
Or you need someone local with a faultmate or similar to enable it for you Thumbs Up
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #224657 22nd Nov 2013 9:24pm
This is why i keep saying that the wiring needs enabling in the ccf. It will work fine lights etc without coding, however the car wont deactivate the pdc and the suspension will not lock out motorway mode unless it coded in.
Im sure ive read somewhere that the stability control also has a different setting for trailers which wont be activated without coding.... Though i might have made that up..... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #224669 22nd Nov 2013 10:01pm
i stand corrected re the wiring... Thumbs Up ... - .- -.
Post #224671 22nd Nov 2013 10:20pm
Needs enabling as said above Thumbs Up
Post #224698 23rd Nov 2013 12:01am
