Home > Maintenance & Mods (L322) > Sanity check
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Sanity check
Ok my 2004 4.4V8 petrol vogue has started to judder every now and then. Before I start looking for a gearbox specialist in West Sussex I wanted to double check symptoms.
Gear change is smooth
No problem changing gear up or down
Kick down works perfectly
Judder felt at or around 1500-2000rpm and usually starts after or during a roundabout but not always
I haven't noticed and fluctuation of revs at the point of judder.
Squeezing the loud pedal tends to settle things.
Worst case is torque converter - best case is oil levels / quality in gearbox and or diffs
What do you think most likely? "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #224989 24th Nov 2013 8:10pm
RXWRR
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Experienced similar issues, especially when going into or exiting a roundabout at lowish revs...thought it was injectors so tried fuel cleaner, no difference...MD said the injectors were fine, but replaced the EGR valve and it's been perfect since. Good luck in getting to the bottom of it. Better to be irresponsible and right, than to be responsible and wrong.
2010 Vogue 4.4 TDV8 Santorini Black, Jet/Ivory interior
Post #225028 24th Nov 2013 11:29pm
