![]() | Home > Maintenance & Mods (L322) > 2010 MY Rear Number Plate Fixing Question |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Depends on the supplying dealer, they fit the plates however they choose.
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 721 ![]() ![]() |
Mine is stuck on. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Mine too. There is nothing that can't be fixed with a hammer😜😜
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
stuck here.. ... - .- -.
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Thought so, can't wait to see what they have done underneath.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
Regardless of model year there are receivers for screws in the tailgate - every RR I have had though has had the number plates stuck on - I always stipulate to a selling dealer absolutely no screws through my plates or i will not be taking delivery - it's a pet hate of mine - they always look |
Not too sure re insert/drilling
If they drill it then the scraps of metal stripped of their zinc protection will also rattle around in there and be a rust attractor.
I hadn't realized there are fixing points behind the plate so fingers crossed they used those and my concern is premature |
Our RR is screwed! |
Sparkylee Member Since: 15 Apr 2012 Location: Guildford Posts: 85 ![]() ![]() |
We've just changed our plates and the front where screwed and rear stuck, but underneath were 2 pre made holes, sort of shaped to accept fixings, but these had just had tape covering them and then the plate was simply suck over the top |
Just had a look and the screws are in the upper corners so not in the same place as the engineered fixing points that I have seen online. I assume that the dealer has decided to screw through the body and have purchased some rust prohibiter and a touch in pen to sort the hole then will apply some automotive hole tape before sticking a new plate over.
