Home > Maintenance & Mods (L322) > rear wheel alignment ??? really .!!!
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
hi folks..
quick question for someone in the know how,im having my rear bushes done on my 2005 vogue as they are worn and creaking and moaning when i drive and the situation is 10 folds more when i go over a pot hole or a bump,very embarrassing specially when you go past a crowd of people say at the bus stop or so,any way my question to you is this..
ive been told that after i get the bushes done i will need my rear wheel alignment done,how true is that and has anyone who has suffered the from rear bush syndrome had theirs done after having the bushes replaced,am i being lead up to the cash point here or is this genuine talk ??? appreciate all your replies folks.. Very Happy
Post #226551 2nd Dec 2013 5:52pm
Yes, four wheel alignment is a must. Your rear wheels have adjustable camber/(caster) and toe in/out and these need to be set after replacement bushes at the rear, otherwise steering and tyre wear will be affected.
Kwik Fit apparently have "bees knees" kit for this now, but most reputable tyre places will also do it. Prices will be @ £60 upwards. Make sure you get a full detailed printout at the end. .
Post #226563 2nd Dec 2013 6:43pm
Yep quick fit do have very good hawkeye setup at selected centres! They will normally do a free check, then charge to adjust the amount seems to Based on the amount of work required, as the camber/toe will be affected by the replacement of the rear bushes then it is a must, however shold be easy to set as the bolts will have recently been freed off Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #226584 2nd Dec 2013 9:06pm
Dolphinboy
PROTYRE did mine for £50. I believe there is a specific 4 wheel drive piece of testing kit required?
Post #226599 2nd Dec 2013 10:23pm
Hawkeye has the settings for all cars including ffrr, wheels have sensors fitted and a a laser on the base unit scans the wheels to guage the camber castor and toe of all 4 wheels.
It is preferable to have the car in tight tolerance mode when the alignmnent is done as variations in the suspension height can affect the reading however many plances which offer alignment dont have the kit to place the car in ttm. There is nothing that can't be fixed with a hammer😜😜
Post #226601 2nd Dec 2013 10:31pm
greasemonkey1
CHEERS GUYS... Thumbs Up Bow down thats the beauty of this forum,you get genuine honest answers... million thank yous..
Post #226605 2nd Dec 2013 10:50pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Hunters wheel alignment system is probably the best known.
its what kwik fit use . 2011 4.4 TdV8 Nara Bronze
Post #226613 2nd Dec 2013 11:23pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Another heads up for KwikFit. Mine drove like a different car once I had it done at KF with the car feeling like it had just rolled out of the factory.
Post #226728 3rd Dec 2013 7:13pm
