Home > Technical (L322) > lumpy idle generally after stood for couple of hours!!
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Anyone who has read some of my previous posts will know I have had all sorts of problems & have had to replace several injectors over the past few months. This is different though & is not under load & not showing any cylinder/injector faults. In fact it drives impeccably with in a few seconds of start up. I have read the codes & it has two which keep coming back P1623 an immobiliser code & U0400 instrument cluster which will not clear. Any thoughts or info on where I can source wiring/ canbus info would be gratefully recieved. i would add it has had a new alternator & varta battery recently.
Mike Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #228146 10th Dec 2013 9:46pm
