Home > Technical (L322) > IID tool arrived today!
Andy
Got one off eBay for £200. Emailed GAP this morning and got activation code within 2 hours. Impressive given they don't work Saturdays! That's great customer service that is!
Just had a play with it. Lowered the suspension in access height and it's a lot better for my wife to get in now.
Still no FBH though. Turned everything on in the settings but nothing on the Nav. No doubt I'm doing something wrong/ missed something.
Post #229168 14th Dec 2013 8:08pm
comports
Once you turned it all on did you do a dash reset..? Apparently you have to do this so it appears on screen.
That's what I had to do anyway and it worked fine. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #229169 14th Dec 2013 8:19pm
Andy
How do I do the dash reset? ( told you I'd missed something!)
Post #229170 14th Dec 2013 8:24pm
comports
one of the settings/resets using the IID magic..! (it really is a great bit of kit)
Can't honestly remember which one I saw it in but will look tomorrow if I get a chance. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #229171 14th Dec 2013 8:26pm
comports
And a quick search found this. I think it will be in the IP-INSTRUMENT PACK section Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #229172 14th Dec 2013 8:28pm
comports
sorry another post but...
You have to do the reset via a hidden menu (found thanks to Steve @ GAP)
Taken from here
Ignition key must be “off”.
• Press and hold the Check Control button in the instrument cluster (RIGHT button), and turn the ignition key to the first position (KLR).
* You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
* Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits (not 6) together and write down that number, you will need it for unlocking all the functions. Example: A123457 will lead to 2+3+4+5+7 = 21
* Push the right button until you see "Test Nr.19"
* Push left button until you see the number that is equal to the one you calculated above
* Push right button again
* Using the left button select 21. Reset all defect codes
* Press the Right button to select. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #229175 14th Dec 2013 9:01pm
Andy
I'll try that- thanks.
I did think it was just a case of changing it on IID though.
Post #229179 14th Dec 2013 9:26pm
mjdronfield
You have to change it in 2 places in the IID Tool and then do an instrument pack reset.
I believe you can do a reset by disconnecting the battery, but I did the test procedure, as pasted above.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #229182 14th Dec 2013 9:43pm
Andy
At long last, Aux Heating is now showing on the Nav display! Couldn't find it using instrument cluster reset though, so I just disconnected the battery.
I've just tried to pair the T91 remote that I bought off eBay with the T60 unit in the boot, but it won't pair. The LEDs just keep flashing. I haven't got an antenna though, so that might be why.
I tried aux heat using the timer but it blows cold. It is showing 16 degrees on the dash, so that might be why. I'll try it again in the morning.
Post #229286 15th Dec 2013 3:36pm
SteveMFr
Site Sponsor
16°C Shocked
Where do you live, Gabun? Laughing
The FBH should fire even at that temp. Give it 5+ mins, the start up sequence takes a bit and once it is running it still takes a while to heat the coolant.
You should hear the FBH after a min or 2 outside the vehicle.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #229341 15th Dec 2013 6:20pm
Andy
Yes, I was surprised to see 16 degrees on the screen too!
I can hear the FBH running - I can hear the exhaust as well so all should be well.
Post #229351 15th Dec 2013 7:01pm
SteveMFr
Site Sponsor
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #229360 15th Dec 2013 7:41pm
