![]() | Home > LPG > LPG grief |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
he has done a lot of work on those systems and fitted them in the past so well worth giving him a go |
Tallsaj Member Since: 23 Aug 2013 Location: Birmingham Posts: 75 ![]() ![]() ![]() |
Ok thanks I take it you know him well? |
probably known him for 15 years now had a number of BRC kits off him in the past for DIY fitment on my past ranges and discos
Ok thanks. I just he can suss my problem out. Can I mention ur name? Also is ur range SC? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
I can recommend a very good guy off Jn 13 of the M5... 60 or 70 miles south of you... Rob Gallop @ Autogas Logistics 01453 825932 |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Could be a MAP sensor related fault. Also, does your LPG conversion have an OBD2 connection for the LPG ECU to monitor and adjust the mixture ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Hi mine is abrc system not sure if it has a obd to adjust the mixture |
CG what system U got fitted to your sc? |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
make sure the air intake pipe to the engine is not come adrift or not tightened up properly ,allthough mine is the bmw m62 and not the jag sc but had the same fault on mine the eml would come on but the car drove fine the intake pipe was not on properly and was taking in air after the air filter and maf sensor which made the eml light come on
I've got an EMER system fitted, runs fine........ Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
