Home > Technical (L322) > What is this switch for
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
Not long had my rr on cleaning the interior I found a toggle switch directly above the brake pedal on the underside of the kick panel it has arrows on it pointing left and right, can anyone give me a clue what it does.
Post #231169 24th Dec 2013 12:58am
DO NOT...i repeat DO NOT move the switch to the other position when the engine is switched on Shocked Shocked Shocked
Post #231173 24th Dec 2013 1:17am
Watty
What does it do?
Post #231179 24th Dec 2013 1:35am
adigorn
Its transit relay switch should be disabled during properly performed PDI
(by removing fuse 11 or 10 cant recall correctly)
if its lightning up the dash when pressed (when key is out and engine off)
it means PDI-ing dealer did not have a clue (or someone replaced the fuse after)
Post #231180 24th Dec 2013 1:36am
Watty
Thank you will check that in the morning 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #231181 24th Dec 2013 1:47am
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
We learn something new every year.....day I mean Wink
Post #231190 24th Dec 2013 3:32am
Watty
Switch is disabled thank you 07 Vogue SE Java Black 3.6 TDV8
Post #231662 27th Dec 2013 11:23pm
