![]() | Home > Maintenance & Mods (L322) > Water ingress but not in the normal places-update a year on |
Sunroof drain tubes? Present :2008 TDV8 HSE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35790 ![]() ![]() |
^ +1 ... - .- -.
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
I have checked the sunroof drain tubes and water does go through them although a bit slow...........if they were blocked how can the water get from the sunroof gutter to the foot well, surly I would have water over flowing into the headlining first which is still dry |
have a read of the following Steve, the threads should help diagnose the problem,
Thanks Stan, will take a look tomorrow and try to get some line down or up the drain tubes, still not sure how the water gets out around the tube to the foot well...............do the front drain tubes go down either side of the windscreen and the rear tubes inbetween the front and rear doors ? every one keeps talking in A,B or C pillars |
well I couldn’t wait as we have more rain forecast. I used some bike brake cable from under the car on the passenger side having pulled the drain bung out and proceeded to feed it up the tube. After some wiggling, the cable not me,.... some very grubby water exited out of the tube and down my arm so i guess it was blocked.
i think in one of those threads i've listed for someone mentions a one way valve which might be stopping you from getting in from the top... ... - .- -.
I spent the morning while it wasn’t raining drying out the passenger carpet, few panels off prop the carpet up a bit, hot air fan heater under carpet..........all good and nice and dry.......
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
HSE gloater troll |
well, its almost a year since i posted my water ingress issue under the passenger carpet, ive spent many an hour trying to find where the water enters the car including the sunroof water drains which having double checked they were clear and making sure they remained clear each month did not stop the water appearing under the passenger carpet............many things since then have been removed, checked and put back but alas ive had to dry the underside of the passenger mat every 2 months or so.........
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8761 ![]() ![]() ![]() |
Move house, to somewhere with a flat drive..... Only sensible solution! There is nothing that can't be fixed with a hammer😜😜
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Or park other way round on alternate days |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
You could try taping the doors up externally with Duck tape to guarantee they are water-proof and then hose the car down and see what happens. If nothing gets in you've found the problem.
