Home > Technical (L322) > bong..... |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Check battery if fine I would do a hard rest leave disconnected as per wiki and see if that clears if not might need more investigation. Present :2008 TDV8 HSE
2nd Jan 2014 8:39pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
+1 battery first |
2nd Jan 2014 9:55pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Will check battery tomorrow, but its a new battery fitted when I had that small issue a while back!
2nd Jan 2014 10:24pm |
Yep short runs a killer Present :2008 TDV8 HSE
2nd Jan 2014 10:49pm |
Anything under about a twenty minute journey and you and up in negative equity with your batterie . Mine dropped to below starting point the other day with just a hand full of short runs and i'm now on a program of ten float charges to condition it back up to health . 2008 MY Supercharged
3rd Jan 2014 2:00am |
Well this morning I checked the battery before starting the FF, 12volts bang on, I charged the battery with trickle charge for a few hours before going out just in case. I also checked the load when lights and other electrical toys on to see if alternator was charging as it should, seem its fine as its charging between 13.2 to 13.9 volts.
3rd Jan 2014 2:04pm |
