![]() | Home > Technical (L322) > EGR gunk |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
Blimey that’s a fair bit of carbon build up...........i didn’t clean the manifold when i did mine but didn’t have quite the same build up as yours. I did clean the entry hole into the manifold being careful not to let any bits drop inside.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
mine was bad but not as bad as yours..i just cleaned as much as i could see before the blanking.. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Wow - that is a bad one. I would run some fuel cleaner through the tank for a few fill - ups. I would also use Shell V power for a while (if you can get that in Ireland) |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Here's mine after circa 120k miles - 2003. No idea if it's original or been cleaned, but not during the 50k miles of my ownership.
