![]() | Home > Technical (L322) > Air Con Issues |
| Liszt Member Since: 22 Apr 2010 Location: Northants, Uk Posts: 15
I had mine regassed a couple of weeks ago. It a slam panel label saying it had last been done in 2007. My chap said there was no refridgerant in the system but he refilled it with the UV dye in the refridgerant. Didn't work first time so he drained it and refilled it and got the car down to 5.8 degree C. Which is fine for me.
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
I had my P38 regassed by kwikfit, they sucked all the gas out but didnt put any back in, I only noticed because I looked on the print out. They even had the cheek to say the system was cooler than before. So get it done by a garage you trust before you start worrying unduly. Dan
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884
Does the electric fan work? |
| IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502
I had mine re gassed and it worked for about a week then no cold air.
With the recent good weather have been driving the soft tops, but was in the FFRR a couple of days ago when it was hot and no air-con. So took advice (from here) to head down to Kwikfit.
| RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597
5kg out, 510kg in , that's one gigantic air-con system you've had installed!! |
That's what the Kwikfit man told me and I saw it on the readouts, whatever, it works now Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Can someone pleease tell me if the electric fan spins when compressor engages? Mine has been replaced and still doesn't turn... |
| dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477
Which electric fan? I've not looked specifically at the FFRR yet (as my aircon would still freeze the balls off a brass monkey).
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
I'll have to take a closer look at the LM's electrics, but generally there are 2 switches on the high pressure lines of an AC (well 3 actually): low/high for the compressor and a somewhat-less-than-high-high switch for the fan (condenser fan all the way in front). Generally, the low / high is somewhere in the vicinity of 2 bar / 30 bar (the compressor will only switch on in between) and 18-25 bar for the electric fan.
| GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75
There's no way you've had over half a tonne of gas added to your system. Not sure you should be reading this bit. |
It's just I have never seen that electric fan spinning, ever! The viscous one does a lot when it's hot but never the electric (the one in front of the radiator) one... |
So what did the readout mean? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
