Home > Technical (L322) > Disaster Non Starter in the dark and wet. |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Nightmare ! Only blessing is that it wasn't at side of the road somewhere miles from home!
5th Jan 2014 5:29pm |
Short trips are a killer in this weather, heaters on etc, the fbh will fire automatically if its cold enough and keep running after you have switched the car off..... So even if you are careful it will flatten unless you give it a good run at least 20 mins every couple of days.
5th Jan 2014 5:55pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Yep seems to be prevalent happened me also no more FBH for me. I have bosch battery too the larger 920 110 version and its also only about 5 months old having replaced it under warranty after 2 years. Present :2008 TDV8 HSE
5th Jan 2014 6:08pm |
steves025uk Member Since: 24 Oct 2012 Location: London Posts: 52 |
"You sure it's only 800? Fairly sure the one I just took out was 850, and the upgrade "we" generally go for is
5th Jan 2014 8:04pm |
