![]() | Home > Maintenance & Mods (L322) > F*****g thing won't start!! |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Disconnect the battery reset the car. |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 ![]() ![]() |
I will give that a try tomorrow, Battery is ok I think, although sometimes I get HDC inactive on first start in the mornings so maybe it's on its way out. |
Battery goosed. |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
I think you're right . HDC message is what mine did regularly.
What's the best course of action?, call AA booster pack, the put a new battery in?, it's doing some very odd things electrically so would assume it cold be the battery actually knowing what FFRRS are like!!. |
Best option would be to change it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
...and dont forget to do the steering lock fully left and then fully right ...how to in the wiki.. |
No worries Stan, I learned that trick well from my previous FFRR |
bosch/varta 020, 110amph, 920cca is the best.. |
Well it turns out it was a bad connection to the Earth on the Battery, battery is fine, car is running fine now, quite a relief, I might still get a new battery although mine is only from 2012 apparently so I will wait and see if I get another HDC inactive in the morning first. |
how did you find that it had a loose connection ?.. |
AA man was wondering why it wasn't cranking even with booster power so ran a tester on it, turns out the Negative terminal had some play but it looked like it was fully done up, un did it and re connected it properly and all seems well, the car cranked really well from cold under its own steam without any booster.
Disconnect the battery again and do a reset |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 ![]() ![]() ![]() |
hi Nappler,
