Home > Maintenance & Mods (L322) > 2004 rear brake discs & pads
comports
Hi all,
Adjusted my handbrake today (thanks to the guide in the how to section) but noticed the discs and pads are nearly shot!
Will ask Mr Dan for updated prices but wondered if there's anything special I should know about replacing them. I note I must slacken the handbrake adjuster before removing the disc. Anything els?.
Not sure if I have pad wear indicators on mine? Should these be replaced and should the handbrake shoes also be replaced??
Thanks folks! Ash
2016 SDV8 AB
Post #234366 12th Jan 2014 9:28pm
Handbrake shoes are not dear so might be worth changing them as part of the job as they do like to crack over time with heat Thumbs Up
Post #234408 13th Jan 2014 12:38am
You should have a wear indicator on the right hand side (drivers). On removal prepare for the little brass spring to ping off and get lost Smile
Get the drum brakes as loose as possible, as the shoe retainers may pull through the dust guards, creating more work Embarassed .
Post #234419 13th Jan 2014 2:36am
