Home > In Car Electronics (L322) > Navcoder
Andy
Navcoder
Anyone got it and if so, what are your experiences?
My experience with it leaves a lot to be desired to be honest!
Post #234477 13th Jan 2014 12:18pm
I have one, connected in via the Resler USB interface on my car PC (very useful for setting up and debugging). Useful for grabbing checking canbus codes, and a few settings, does a good job with the PDC too, and allows setting TV in Motion. I paid up for the full version, but once I got all the settings I needed I haven't used it since.
http://www.navcoder.com/
http://www.navcoder.com/downloads/NavCoder...coder28350 .
Post #234572 13th Jan 2014 7:55pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
hey joe
i would like to turn my tv in motion what do i need please
Post #241152 8th Feb 2014 10:58pm
dan_uk_1984
Joe has provided a link to the software.
You need. 1. A usb interface and 2. The software.
You need the resler ibus interface - google Smile
Take a look at this: http://www.fullfatrr.com/forum/topic1797.html?highlight=navcoder
Sheep
Post #241156 8th Feb 2014 11:01pm
Just for completeness:
http://www.reslers.de/IBUS/
Here also is the wiring diagram, ignore the green wire as this is for switching the screen over to reverse cam. You will find all the wires you need in the boot somewhere.
Post #241164 8th Feb 2014 11:28pm
Andy
If you don't mind waiting weeks for a reply to your (many) questions regarding Navcoder, then get vague responses or auto replies but no actual solutions, then go ahead and fork out £22 for it. Good luck getting it to work though.
I downloaded the Beta software and bought an obd cable which the author suggested would work. He later said it wouldn't work even though he lists it on his website. He then advised getting a serial port cable so I did. This time, I bought one from eBay along with an adaptor cable with USB connectivity. He then said USB wasn't reliable.
ended up buying another serial port cable and hardwiring it into the loom and it's still hit and miss. I then tried his older version of the software which worked better.
I emailed him to tell him this and his reply was " yeah, the beta version does seem to be a little buggy".
You don't say!
I got a refund in the end from my bank as Paypal wouldn't refund, due to it being non-tangible goods.
Post #241873 11th Feb 2014 10:31am
mjdronfield
I have it. No major issues other than as joe90 says, it's not great at connecting first time.
I also have the iid tool, which covers stuff navcoder doesn't.
I've set up what I want, and then hardly need to use it.
Does what I want in the end though.
Over time, I think the chaps at gap diagnostic and the iid tool may add config functionality to that, so may be less of a need for navcoder. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #241998 11th Feb 2014 6:20pm
