Home > Duckworth Parts > Rear Camera Replacement
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Dan, I think I have the first gen rear view camera which only works after a hard bang of the fist with the image quality ranging from OK to shadowy shapes in black and white.
I know that I can update with a Hi Res version with yellow lines but would have to rewire and move the mounting point. Is there an alternative, I have seen mention of a CCD between the CMOS and Hi Res, if so id this a straight replacement and what is the cost of all the part I would need. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #235591 17th Jan 2014 8:37pm
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
These one's work
http://www.ebay.co.uk/itm/170-Car-Waterpro...3f2db12fc5
However theres a lot more out there now. So i would do a bit of research before buying.
Its an easy DIY job as i did it on my last car.
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #235606 17th Jan 2014 9:44pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hi Jay,
Do you have any pics of the install by any chance? I got the camera but terrified of messing something else up when I start cutting African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #235609 17th Jan 2014 10:02pm
JAYBOY
Sorry but i don't.
If you want to do it then you could send me a PM and i would be able to talk you through it.
You just need a good soldering iron and some heat shrink.
There is a coax connection that you need to cut off the plug to and solder the yellow wires to.
If you do a search there may be an how to. I think stuart was going to do one.
its an easy one to do Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #235610 17th Jan 2014 10:10pm
rej
Thanks for the suggestion. I am really after one thing that is plug and play as I don't want to star cutting wires etc. There is a difference between knowing your sh!t and knowing you're sh!t
Post #235912 19th Jan 2014 6:29pm
rej
Dan, if there is no plug and play upgrade, what is the cost of the original camera as I would rather have the original working (albeit with lower quality than some options) than just have a black screen most of the time which is what I have now.
Thanks in advance for your help There is a difference between knowing your sh!t and knowing you're sh!t
Post #236046 20th Jan 2014 2:37pm
duckworthparts
Site Sponsor
original. - choice of 2, your MY is right on change over would need full VIN
upgraded 2010 camera, does need wires cutting i think..
camera, harness, holder £215+VAT You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #236055 20th Jan 2014 3:12pm
rej
Dan, VIN# is SALLMAM********** if this helps. There is a difference between knowing your sh!t and knowing you're sh!t
Post #236057 20th Jan 2014 3:22pm
rej
Also Dan I understand that you can decode the buold sheet so I can see what the car actually came with from the factory. There is a difference between knowing your sh!t and knowing you're sh!t
Post #236058 20th Jan 2014 3:24pm
duckworthparts
Site Sponsor
direct replacement for your MY XVI500120PNP £152+VAT
little bit later MY and they're £400+ You can paypal direct using - www.paypal.me/duckworthparts
Post #236059 20th Jan 2014 3:26pm
duckworthparts
Site Sponsor
yes PM me your email and i'll send across, also delete your VIN off the thread Thumbs Up You can paypal direct using - www.paypal.me/duckworthparts
Post #236060 20th Jan 2014 3:26pm
rej
Dan,
Thanks for the quick reply, I, will stick with the original which I work out to be £182.40 with VAT unless the £400+ one has the same fittings and a better image in which case I would go for that.
I am also looking for the "Water Shedder" thing to protect my electronic boxes if that is still available to order.
I will pm you e-mail and have deleted the VIN from the post.
Is paypal best or do you prefer a normal credit card etc... There is a difference between knowing your sh!t and knowing you're sh!t
Post #236061 20th Jan 2014 3:33pm
rej
Sorry to keep adding, do you do the silver bulbs for the front indicator to get rid of the "fried egg" look. There is a difference between knowing your sh!t and knowing you're sh!t
Post #236063 20th Jan 2014 3:36pm
duckworthparts
Site Sponsor
the £400 camera isn't a better quality image, only the later 2010MY is, think there are some how to guides on here though.
don't do the silver bulbs i'm afraid
water shedder £12inc vat
paypal to danroberts@duckworthlandrover.co.uk
or you can call if you want to pay with card. You can paypal direct using - www.paypal.me/duckworthparts
Post #236064 20th Jan 2014 3:40pm
rej
Thanks for the build info very interesting.
OK can I please have if available:
1 x original rear view camera
2 x water shedder
2 x Silver bulbs for indicators (in headlamp units)
1 x Venture cam mount(s) - The bits that you put the venture cam in and stick to the car/trailer etc...
If you let me have the total including VAT and postage I will make payment by return. There is a difference between knowing your sh!t and knowing you're sh!t
Post #236069 20th Jan 2014 3:54pm
