Home > Maintenance & Mods (L322) > Steering wheel lock sticking--CURED !!
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Steering wheel lock sticking on a 2004 Td6 Vogue which meant it wouldn't send a signal to the Ignition barrel so key wouldn't turn. Found this on the web so decided to give it a go as owner has already been quoted £1,500 for replacement steering column .
http://www.blackbox-solutions.com/photos/L322lock.pdf
15 mins to carefully drill hole, one squirt of a WD40 type fluid and 10 seconds later key turns in ignition. 20 mins putting key in and out and not once did fault reoccur.
Who ever discovered this is a genius !!
Post #235612 17th Jan 2014 10:16pm
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
unfortunately this mod didnt work for me but fair play to them for going to the effort of working it out and posting it up for us all to learn from,sound bloke
Colin is a member on here under "BBS GUY"
Post #235624 17th Jan 2014 11:14pm
verydisco
thanks for sharing Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #235646 18th Jan 2014 1:01am
DaveK
Just cheked with the owner and everything still working !
Post #235887 19th Jan 2014 4:10pm
