![]() | Home > Technical (L322) > Sending my FBH pcb off to France. |
Hi Noddy, If you check the RAVE on the FBH / Park Heat description, you'll see that there is an additional water valve that closes for a period when park heat is run: this is to warm the large interior of the RR before the motor gets tossed into the loop. By simply activating park heat on our RRs, we are warming the motor from the beginning. If you let the FBH run a full 1/2 hr, it should be quite warm in the car (I don't know if I'd call it toasty, tho). A short run on a cold day will not warm the car significantly. But it gets really warm really quickly when you start the motor because the motor is already nearly warm. There should not be a significant amount of condensation in the vehicle. Either it is typically Brit weather and you are getting in and out with very wet clothes often or you have a source of moisture somewhere - as in leak. Also, do as DanUK1984 always said: run the AC all the time (and make sure recirculate air is off or an auto but open). ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
It's only started fogging up since I cleaned the inside of the windscreen with anti-fog window cleaner weirdly! |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Surprise, surprise Mike has found two failed resistors and has made the repair.
get246 Member Since: 29 Nov 2013 Location: Farnborough Posts: 5 ![]() ![]() |
paulB thank you very much for that you are legend……. |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Hi guys, can someone be so kind as to let me have the address of the company repairing FBH in France.
I'd like the address as well please as mine only blows slightly lukewarm |
CSK.
Noddy
Thanks Paul, just called the stealer who says he replaced the pump and he says it is working now but I won't be able to test it myself as they are now sourcing the DVD player problem (DVD stopping and restarting from time to time). I hope to get my car back soon as I do miss it! |
Glad you got it sorted |
Well I thought they sorted it out but I called the dealer today and they tested the FBH the last 3 days and the cabin was hot on Monday and Tuesday morning but this morning it didn't give any heat again! Very frustrating! They replaced the FBH and the fuel pump and tested the electronic bit but it stopped giving any heat again. They reported all this to Land Rover and are awaiting instructions. Starting to think to ask them to leave as is as I'm getting fed up not having my car on the other hand I'd like it sorted! |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Probably didn't run it for the full cycle .... |
Apparently they did. They switched it on and checked after 30 min. Two first days it was warm, third it was not. Go figure! |
