Home > Technical (L322) > Puzzled
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Puzzled
Any help / ideas would be most welcome...
Was checking faults yesterday with "allcomms"..
car cuts out... fuel light on (compter says 31 mile range) so don't think it ran out, but...added more fuel....wont start...
flatten the battery trying to start her...recharge battery... try again.. wont start...
just wont fire...checked all relevant fuses, done battery reset...charged battery again..
still no fire... free use of "RSW" all comms to anyone nearby
Post #236022 20th Jan 2014 1:04pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Ignore the range, was the fuel light on?
How much fuel did you put back in? I suspect not enough, put more fuel in would be my first action, at least 10-15 litres.
Post #236140 20th Jan 2014 8:26pm
mjdronfield
Other than the above, you could try connecting the allcoms again and disconnecting, in case it did not disconnect properly last time.....
Bit of a long shot I know...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #236156 20th Jan 2014 9:43pm
Have you checked fuel is pumping to the engine?
Do you have a spark?
(The old ones are the best ones Smile ) .
Post #236182 20th Jan 2014 11:22pm
hoppy
put 30 litres in, connected allcomms 3 times....
fuel is a trickle... wont get chance to do anymore till the weekend now..
hoping its just a new fuel filter needed... knowing my luck will be the pumps... Sad free use of "RSW" all comms to anyone nearby
Post #236189 21st Jan 2014 12:12am
hoppy
Puzzled no more.... Very Happy
found this excellent write up on an other forum the other day...
http://www.landyzone.co.uk/lz/f71/4-4-v8-b...00394.html
followed the instructions.... jobs a good un.... Thumbs Up free use of "RSW" all comms to anyone nearby
Post #237077 25th Jan 2014 4:59pm
SaintV8 is great!
But remember the good old days of SU fuel pumps: undo inlet and outlet, disconnect live and earth, undo clamp bolt, remove. replacement in reverse 10 minutes ? Thumbs Up .
Post #237090 25th Jan 2014 5:52pm
in our wiki as well,
http://www.fullfatrr.com/forum/topic16152.html
Post #237095 25th Jan 2014 6:05pm
