![]() | Home > Technical (L322) > MOT Bits... |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Ok Well todays failure sheet reads like war and peace and im sure some of it is trying it on....
Now CV Gaitor i knew about so thats going to be done anyway, and the anti roll bar isn't a biggy i'll try that one myself i think, The handbrake i'm going to have a go at as well to see if i can make it any better but low and behold even after telling the tester that the auto adjustment has its moments and he said he tried it. I did it on the way home and had it not all the way up and resisting forward and reverse drive whilst engaged without any throttle(which it didnt do before i did the auto adjustment) So that should be too bad.. The undertrays and all are worrying.. why would landrover fit them if they were an MOT advisory?!? Also looks like i need the front arm as well. I tried a search of the forum but cant find 47p2's post on the neoprene one as i intend to get the bits and get a garage to do it on wednesday Am i missing anything?? PS the front pads have a fair old chunk of meat left on them i feel and i'd say 30%+ left in them easily.. I'm not sure of point 001 though as the only thing the dash warns me of is a front foglamp being out. Are these now an MOT fail?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. |
For the auto hand brake adjustment most cars if you partially apply the handbrake and then use the foot brake gently all the way to the floor or as far as it will go a few times. It works on almost every car i have come across.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Don't quite understand how the "auto adjust " works on a FFRR but I'll try anything once. |
Caliper and carrier of on the FFRR |
Oh well that's tomorrow night sorted I guess |
Well the handbrake adjustment worked, FYI to tighten then you need to flick down and not up |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
See my off topic post on council MOTs 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I did cheers noddy but they weren't open yesterday and booked till Wednesday |
| paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422
Hello Gents. Had an MOT advisory that I need to get round to sorting, but not sure what the tester meant so wondered if anybody could enlighten me on the part name / number. I understand the dust cover may not be separate part, so an assembly may need to be purchased.
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1565
The linkage are the bars that run vertically joining the roll bar end to the strut just below the air bag amd don't have dust seals .... At least they didn't on mine. Don't understand that one personally V8 or else ... |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
They do have dust seals
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
i believe that the ball joint gaiter/dust cover is a recent, (this year?) addition to the test, so expect a few more fails this year than ever before, like the SRS light was last year. these VOSA whitecoats, have to justify their jobs, so they think up something every year! plus I also seem to remember reading that if a light is fitted it must work. ie front fogs etc. same as if the car has headlamp wash/squirters, they have to work too.
Thanks for the great photo...looks like a fairly easy job to do. |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Will the first fail/advisory show on the online MOT record? |
