Home > Technical (L322) > Re-Conditioned 3.6 TDV8 Engine
Jacobite1746
Well looks like my RRS will probably need a replacement engine after initial diagnostics. These engines seem to be like 'hens teeth'. Anybody got any suggestions of a reputable source. I have seen a couple NWS Motor Services, 1st Choice Engines selling re-conditioned engines.
Cheers in advance
Post #238403 31st Jan 2014 5:40am
Bad news , what's happened to yours ? We hear about RRS lunching on their turbos quite a bit here , seams to happen less in the FullFat so I have not heard of many people needing to find one . 2008 MY Supercharged
Post #238406 31st Jan 2014 5:49am
Odd that they seem to go in the RRS and not RR?
Post #238422 31st Jan 2014 8:11am
if you have a RRS , you do realise that you are on the wrong forum...
the RRS forum is located here, http://www.rrsport.co.uk/forum/
Post #238431 31st Jan 2014 8:33am
JAYBOY
Wales 2017 Range Rover Autobiography 5.0 SC V8 Corris Grey
I think its got something to do with cooling there's a lot more room around the turbos in the FF so they cool better. If you've seen them on a sport there impossible to get to without taking the body off.
My brother had 2 turbos go on his sport. body off both times. Shocked 2020 Porsche Panamera Turbo Hybrid (V FAST)
2017 Range Rover Autobiography 5.0 V8
2018 JCW Mini Cooper
2018 Skoda VRS
Post #238447 31st Jan 2014 9:58am
n1cktdv8
2008 Range Rover Vogue TDV8 Stornoway Grey
Body off Shocked I have seen that done on a D3...hell of a job...
Best of luck getting it sorted Big Cry Is this where I put the car details and a bit about myself ?........
Post #238451 31st Jan 2014 10:06am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Taking the body off is actually pretty straightforward (although you can do V6 Discovery and Sport turbos without).
Post #238463 31st Jan 2014 11:03am
Martin
Site Admin
If it's anything like the TDV6, there are no or virtually no internal engine parts available - which makes the availability of "reconditioned" engines somewhat suspect.
I would want full confirmation of all work done on a recon engine before purchasing.
Post #238465 31st Jan 2014 11:43am
OP has gone over there, http://www.rrsport.co.uk/forum/topic34598.html
Post #238470 31st Jan 2014 12:29pm
