Home > Technical (L322) > Deployable side steps not deploying. |
Just a guess but press and hold the retract button? Works for the sunroof...... There is nothing that can't be fixed with a hammer😜😜
30th Jan 2014 12:40am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16174 |
Battery reset? |
30th Jan 2014 12:54am |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 |
It sounds like your steps are turned off. Here are the operation instructions, try the very last bit.
30th Jan 2014 12:57am |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 177 |
This is so embarrassing. Thanks for the tips. I should have tried the obvious first!
30th Jan 2014 1:00am |
Out of interest, how does the above procedure work on a post 09 car without a key? |
30th Jan 2014 1:01am |
Good question, I don't really know as I have never played with one. I would presume that like with other manufactures there is a way of selecting the aux ( position 1 ) and ignition (position 2) using the stop start button, maybe without putting your foot on the brake pedal and holding the button for a number of seconds, this is the procedure in our Volvo. MY2007 S/C - Stornoway / Jet |
30th Jan 2014 1:17am |
No sir, ign on or engine running... No ign 1 & 2 |
30th Jan 2014 1:20am |
Looks like my steps were turned off and once I re activated them according to Jon's instructions, they are working again!
30th Jan 2014 2:34pm |
