![]() | Home > Technical (L322) > mapping |
| fil b Member Since: 08 Nov 2013 Location: poole Posts: 14
Hi all, is it safe remap a vogue 2003 with 103000 on clock ? |
| JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204
Diesel |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
dont waste your money, i had my td6 done and it didnt do anything...you'd be better off putting an egr blanking kit on.. |
yes it ia a diesel td6 |
As Stan said |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
With over 100K on the clock wouldn't it be a big NEW strain on the engine |
I see where you are coming from, but the gearbox issues are not torque related, and I understand there are less turbo issues after remap - though I did read that on a BMW forum, and can't remember which one. Something to do with the way it spools up.
mjdronfield
Yes, also a valid route to a quicker more driveable Ffrr. Especially as the tdv8's are getting cheaper now.
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
Yes it is worth it depending on who's map it is. The TD6 is a very under stressed engine and BMW even did their own power upgrade. I had a td6 from new several years ago and put over 80k miles on it with absolutely no issues at all. I went with a JE Map after thorough research and also looked at DMS, Autologic, Overginch etc.
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
As Stan says I would do the EGR blanking thing, seems to work for everyone, the TD6 is what it is, if you want an X5 then buy one, IMHO |
| RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186
I have had my td6 remapped after about a month of owning it with 90k on the clock. I am very happy with the results more power, better mpg and it does not change down quite so quick when going under load. As it has been stated they are very under tuned in the ffrr.
| All times are GMT |
