Home > Technical (L322) > Rear Disc's and Brake Shoe Q?? |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
I'd be inclined to check the handbrake shoes. A rub with some emery paper or similar will be all you need in most cases. |
1st Feb 2014 8:28pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Neil, don't forget to back the handbrake shoes off before trying to pull off the rear discs sir... Last thing you need to do is pull the pins through the back plates |
1st Feb 2014 11:42pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
cheers guys, Craig yeah done that years ago on a ML oops |
2nd Feb 2014 7:36pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I read that if you release epb with engine on then turn off car the discs can be removed without need to wind back handbrake shoes? Present :2008 TDV8 HSE
2nd Feb 2014 8:53pm |
Depends if they clear any lip on the inside of the drum There is nothing that can't be fixed with a hammer😜😜
3rd Feb 2014 7:05pm |
