Home > Technical (L322) > Snap on diagnostic
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Snap on diagnostic
Hi will a snap on diagnostic system update my firmware on my 05 3.0 l322?
Post #240281 6th Feb 2014 11:41am
link, pics, specs?
Post #240286 6th Feb 2014 11:56am
Jammer600
Solus pro
Post #240383 6th Feb 2014 4:12pm
it appears hat it can, but where to get the firmware..
http://www1.snapon.com/display/3791/Brochu...nation.pdf
http://www.snapontools.com.au/__data/asset...verage.pdf
Post #240384 6th Feb 2014 4:18pm
SteveMFr
Site Sponsor
Hi Stan,
Where are you taking the update capability from? If you are referring to the "•••• = Model Updated" on the bottom of P. 117 on the second brochure, I believe that just means "The diagnostic software has been updated for this model vehicle" and not "This diagnostic tool will update your ECUs SW".
Jammer, what ECU /system are you trying to update and why? AFAIK, the only diagnostic systems with the capability to flash updates to Land Rover ECUs are: LR OEM IDS/SDD, Autologic, BBS products, and our products.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #240393 6th Feb 2014 4:46pm
i mistakenly thought it could but i wasnt sure hence my question re where to get the firmware....if the firmware was available for the snap-on then it would confirm that it could..
Post #240395 6th Feb 2014 4:54pm
Ragerover
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Zambezi Silver
Nope I've got a solus pro
And unfortunatly not Growing old is compulsory Growing up is optional
Post #240542 6th Feb 2014 10:33pm
SteveMFr
Site Sponsor
Rage, if you don't mind my asking: approx how much was the Solus all in? Do you need it for other vehicle marques?
Did you see our IIDTool Pro announcement at the top of the tech section? I imagine the Solus is approx like a Hawkeye/Lynx (or slightly less) on Land Rovers - do you know? Compare to our Pro?
You can PM if you do not want to comment openly.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #240658 7th Feb 2014 9:28am
Jammer600
Just wanted to turn my nav on the move on, tried the code but it didn't work and someone said about firmware up date, plugged into my mates solus pro smornin, as I had three amber lights on litteraly on turnover then go straight out, showed as glow system and fuel metering thing, reset and we'll see what happends, gotta admit I am tempted with the iidtool but I'm terrible for changing my cars and don't really want to fork out for one then have to sell it really, I would only want to do a few minor things like key in ingnition beep off, fold mirrors on lock, possibly sort nav on move and I don't really know what else
Post #240725 7th Feb 2014 12:11pm
Jammer600
How can I post a video on here?
Post #240853 7th Feb 2014 8:27pm
you cant, you can only put a link on [you tube etc].
Post #240861 7th Feb 2014 9:02pm
Jammer600
Just uploaded it, as you should see, the amber lights light up on start up?? Any ideas?
Post #240879 7th Feb 2014 9:42pm
Ragerover
It has full diagnostics for all models
You can do live diagnostics on the go
You can alter quite a few settings
You can also test individual items and sensors
Not as good as your tool for the range rover for changing settings etc
Cost wise £4k with 1 years updates
This covers all models from year dot to present
Son has his own garage so it's worth it
For every day DIY it's too much
I'll probably buy an iid tool for my rangey though Growing old is compulsory Growing up is optional
Post #240909 7th Feb 2014 10:40pm
Jammer600
Has anyone seen the video I posted? Had my tires fitted and tracking done today, went to rugby then home then popped to shop, came out to the rr unlocked tried starting but it didn't fire, still got those lights coming up, tried again a few times, locked and unlocked, had a message come up, air susp inactive, battery light on and oil light, tried locking and starting etc rang the mrs to come and get me, turned up and I thought I'd try one last time and it started up! Weird?!!!
Post #241129 8th Feb 2014 10:42pm
battery ok?
Post #241139 8th Feb 2014 10:48pm
