![]() | Home > Maintenance & Mods (L322) > Apparently battery drain is the amp?!? Best option? |
i would run the FF with the amp disconnected for a few weeks to see if it actually is the cause... |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Are they a trusted garage in your opinion Nick? I ask because there will be many more components fed by that feed and unplugging the amp may just take out a link in the chain... |
| NickH72 Member Since: 05 Mar 2010 Location: Surrey Posts: 92
Both good points...
the FF has a maze of ecus that 'talk' to each other so the process of disconnecting the amp might have affected another ecu into working properly...just a theory ... |
ok so how an earth do I get to the bottom of it? |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
I would be wary about what a Main Dealer tells you. To find a specific source of battery drain is very time consuming over a significant period of time. I find it hard to believe a Dealer would spend the necessary time and might just opt for a best guess after a nominal investigation.
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
Good advice nicedayforit |
^ I find this convenient for checking battery drain.
| Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126
Nick
Thanks All,
Good news Nick, I will probably be over there Saturday with one amp |
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
Update |
| piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97
Cmmon guys you cant leave me in suspense,update please.
