![]() | Home > Off Topic > Got wood? |
Does anyone on here buy their wood in for a log fire or the like and if so how much do you pay?
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 ![]() ![]() ![]() |
Someone round me sells it for £2.50 a net. The net is about 25x 90cm
Is that about 5-10kg then roughly?
Yep that's soft wood.
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
The going rate for logs in west wales is about £70 per cubic metre and that's a mix of hard and soft wood cut to your required size |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
How does my hard wood compare to your hard wood?
Well Mark if your ever near warrington or runcorn let me know |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
Refuse to pay for wood at the moment with so much lying around. My chainsaw has been working overtime and I've got enough to leave for a year or so to dry out properly.
It's beech, so definitely hard. Ask the supermodels. ![]() |
I was told don't burn it for two years, which is one reason I stock so much - as green wood is cheaper and I have the space. |
I've always just covered it to be honest and in the past my gran folks and parents would just have a decent stock at the sides of the ingle nook and just empty one side at a time and then refil as by the time you got to the other side it was fully dried out.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Have you considered contacting tree surgeons/landscape gardeners? They often are happy to deliver wagon loads of cut up trees and dump it for you for nothing. It costs them money to take to the dump otherwise.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Have you phoned local suppliers? They will tell you exactly how much wood costs to buy.
Cheers NDF, never thought of that and I know an arby as well!
