![]() | Home > Technical (L322) > Smoky fbh |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
I don't think that is the FBH running, I had that happening on both my TDV8, Vogue and Sport, it is a system to warm the fuel when you start the engine by cold weather to prevent the Diesel from freezing.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Short journey? Ian |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
you would only have a remote if it was specified as an option when new,
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 ![]() ![]() ![]() |
Yes both times I had only travelled about 1 mile 07 Vogue SE Java Black 3.6 TDV8
That will be it, the unit has fired up and not come to an end of its cycle by itself. Its been shut down by you, (short journey) I have this and appears normal. We have a VW with a FBH and this is the same on short journeys.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
Normal.
Take it out for a run or let it idle for 30mins to run the full cycle and clear it out, this is a way that can kill them as the soot builds up in the firing chamber and clogs the fan up eventually |
5 pints of Lager feeling great ![]() ![]() ![]() Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
a few more pints and you wont notice any smoke.... |
What smoke !! |
