Home > Technical (L322) > Gearbox failure?
BUSAKAZ
England 2003 Range Rover Vogue Td6 Adriatic Blue
texpis wrote:
We'll done chaps 10 out of 10 Very Happy
Couple of questions, it doesn't look like its had the diff recall done is this still live, I heard somewhere it wasn't.
Is just changing the splined bush and drive shaft straight forward I read something about a crush washer?
Mick
Mick, i had mine done in november 2013 as a recall. Thumbs Up 2003 TD6
1996 4.6 hse (gone)
2000 200 BHP Hayabusa
Post #244000 21st Feb 2014 1:22pm
RRPhil
Yes, it’s vital that the pinion shaft bearings run with the correct preload and the crush tube (item 12 in the diagram below) is a critical part of this :
If you replace parts to the old (spline tube) design the consequence of getting the preload wrong, and the bearings failing as a result, is that the pinion could jam into the crownwheel and lock the front wheels solid. Land Rover never risked this and instead simply fitted new final drive assemblies (of the old design) until the Q041 Service Action came along in June 2008.
You’d be much better getting the new design with the CV joint but, as you can see from the instructions below, the process the workshop guys have to work through to upgrade the final drive is not a simple one :
Phil
Post #244001 21st Feb 2014 1:24pm
BUSAKAZ
Where do you get all the picture's from they are brill. Thumbs Up 2003 TD6
1996 4.6 hse (gone)
Post #244002 21st Feb 2014 1:27pm
texpis
England 2002 Range Rover HSE 4.4 V8 Alveston Red
Thanks for that Phil that doesn't look like something I would want to take on. There seems to be a lot of splined tubes around so I am guessing a fair few are being replaced without any bother, I there anyone on here changed just the tube?
Mick
Post #244023 21st Feb 2014 2:18pm
Rosco
Texpis, did you have any joy with the recall on this one? Very Happy
Post #244676 24th Feb 2014 7:11pm
texpis
Hi Rosco
It's not my Range Rover it's a mates he phoned the main dealer and was told the recall was finished not sure how much pressure he put on. He's had the car from new and only done 30k e must have had the recall but ignored it. I am going to fit new splined bush and prop.
Mick
Post #244731 24th Feb 2014 11:14pm
Rosco
Thanks Mick
was interested as a previous poster had one done in November Thumbs Up
Post #244733 24th Feb 2014 11:16pm
